cr8crshr
- 10:25 AM
- Feb 13, 2009
- Northwest Nevada
Just a quick one here...Where are those, that have them on their carbs, wire the Red wire to. I am currently running it at the positive side of my Ballast Resister...not spliced in which I am assuming is a Positive Ignition point, as specified by my Demon/Holly carb's instructions, and the Ballast Resistor is not wired up directly because of my ECU from FBO Systems for electronic ignition...but I am not really happy with that way. I can run a wire from the choke to the actual positive pin on the ignition switch yet I would like to find a more closer point if I can. Otherwise I do have a number of positive ignition points for use besides that also. I do not have to splice into the existing wire harness at all as I have several electrical buss' that I am also using for my extra gauges and my Tach. Also as well I have an extra buss on the firewall that is used to power the buss' under the dash for the gauges. Thanks for the help...cr8crshr/Tuck
