my 63 2 door conversion alterd
Hey Poly!
Some time back you helped me out on a tip with the head light rings for my '63 Dodge 4dr. I did the same '64 headlight ring conversion and it turned out very nice. Finding good condition/ decent price '63 rings was next to impossible! Thanks again!!
through the bumper on to check the fit needs some tweaking
Now that sounds pretty bad ***!! Just about time for some shake, rattle, and ROLL!! :steering:
Thanks for sharing. I really enjoy all your posts on this project. :thumbsup:
Been gone for a while. You've made great progress! The engine sounds badass.
found a great book on A/FX car of 64 and 65 with all the facks on the chrysler A/FX factory car of witch 11 where built by the factory in 1965 only 6 dodge hardtops and 5 plymouth hardtops witch where banned by Wally parks on the first of january 1965 all other A/FX car buit where by independant drivers the factory cars went to dick landy ramchargers and remaning cars went to the dodge boys these factory cars had 15" rear axle forward and 11 " front axle forward for 110 inch wheel base the 64 cars where owner built and the rear axle was moved forward 5 inches and front axle 4 inches for a 1 inch change in wheelbase the book is how to build an altered wheel base
I don't remember if I asked before, what master cylinder is that? It's the style I want for my '62 with manual brakes.
Also, did you use a new gas tank?
Yes I used a new gas tank and pick up tube 3/8 " fuel line the master cylinder is for 71 with manual disc brakes
