Lazerwolf
The Charger was driving good until last night. Took it for a drive and first 5 miles or so were fine. I pulled up to a stop sign at a busy road and as I started to accelerator, there was a few pops that came from the carb. Never done this before. I'm not taking WOT acceleration here, just normal acceleration on to a 55 mph road. As I came up to the next corner to turn less than a mile later, the car would not idle and died. It started back up and would keep running as long as I kept the RPMs over 1200-1500 or so. Now there was a routine pop out carb, frequency dependent on RPMs so relatively sure it's related to when firing on a cylinder. Car was in middle of intersection so I started it up, kept RPMs up, and moved car to where I could pull over and shut it off. Of course, I had no tools at all with me since this was a short, quick trip. Initial check only found cylinder one wire on the exhaust manifold but it does have Live Wire plug wires (from Davis United) that have the casing good up to 1400 degrees. Moving that didn't help when I tried to turn it over again.
My mind is running the gambit on this one.
1) Timing off or jumped? Distributor was tight and not movable.
2) Plug fouled or plug wire shorted? Would it behave like this?
3) Exhaust valve stuck? Probably beyond my skill level/knowledge.
4) Push rod bent/broke? Definitely beyond my skill level/knowledge.
Didn't feel confident about trying to dry it 5 miles home so having it towed back Monday. What the heck could have caused this and would behave like this? Like I said first 5 miles or so were normal.
Specs are as follows. Original 400 motor with warm unknown cam. Edelbrock aluminum heads and intake. Carb is Holley 4160. Fuel pressure was reading about 6.5 pounds when I shut it off. Temperature and oil pressure seemed normal. It was not puking any fluids so that was good.
Any assistance or thoughts would be appreciated. Thanks in advance, Todd.
