Mike Gaines
- 4:13 PM
- Apr 17, 2014
- Ahwahnee, (Fresno) California
I am asking who uses one of the 2 different ways to launch off your transbrake.
1) Who all uses the MSD 2 Step box with a "low end" chip installed (let's say anywhere between 3k and 5k) and then set the transbrake and then floor the pedal and let the chip limit the RPM by dropping cylinders and then it only reaches your desired rpm with the chip you installed...then lift the button and launch.
or
2) Who does NOT use a low end chip with a MSD 2 Step box and merely sets the transbrake button and floors the pedal and have the motor run all the way up that it will go against your converter and then release the button and launch.
COMMENTS AND ANSWERS....
or
