mopar440bbody
i am still having starting problems with my 67 , we did get some fire out to the plugs but no start. however we did find choke plate stuck and plugs on the 2 we pulled looked full of gas. gona try start in the morning see if it will crank . and i guess change the plugs i just got the car so i knownothing about what has or hasnt been done. i cant under stand why it stalled in the 1st place only problems i found was timing dog (keeper) was loose and had little value ping, on my 1st test drive. motor sounded strong had power and went in all gears.
but as far as parts for ECM and Dist. i ask for 1973 or newer? mopar only makes a few diff models but i am sure to run into problem sooner or later.
