Nacho-RT74
- 12:44 AM
- Oct 8, 2012
- Valencia, España
I meant untouched housing due the supports for the Radio pots, which are tipically also cut when cutting the cluster for modern stereos, but allways talking about the correct hosuing for tach/clock
HOWEVER is also true you can MODIFY a basic cluster assembly to fit a tach/clock. The cluster housings gets all the cast done for both kind of gauges setups, then cut to the assembly will get.
I have got 3 clock clusters and everyone got the molds for the basic cluster setup, just don't cut for the basic cluster gauges location
