BAFRAID
She’s looking like a Super Bee again!!
so I'm trying to decide if I should totally rebuild or just refresh the top end of the 383 in my Super Bee? It turns over. Have not checked compression. Any thoughts?
I called shop here in town to get a general idea of cost to rebuild. He said, for a Longblock, it would be about $2800. He also mentioned that if the compression was higher, 9:1 or 10:1, that would need to be changed to run on today's gas. Is this correct? He mentioned a few other changes that would be done related to more modern parts or hardened steal parts in the heads/valves.
I then talked to one of my friends who is restoring a 67 GTO. He said he is going to rebuild his own engine. He's going to take it apart, check everything and keep as many of the original parts as he can. Put in new bearings, seals, maybe rings, have the heads and block checked for any cracks.
Any thought as far as using the original Pistons, rods, crank, cam?
Thank you Phil! I'm not familiar at all with the balance between cam and compression/stroke. What I ultimately want is a STRONG, mean sounding, reliable engine that is close to stock in terms of looks. It's a numbers matching engine so I hate to alter the block more than needed. Any suggestions or combinations to go with that will provide what I'm looking for?
Thank you, Tad
Thank you Phil! That's exactly what I'm looking for! I'm not to versed on intakes. Is the stock intake considered "nice"? Currently I have the original carb as well as a similar carb that is date coded in the 80s. The porting I am familiar with.
