I see this topic often enough so I figured I would document my procedure.
Old bushing (this one actually fell apart). Notice the inner sleeve stays on the pivot shaft and the outer shell stays in the LCA...
To remove the inner sleeve from the pivot shaft, set it on a vise or anvil and hammer at 12:00 and 3:00. The pivot is harder than the sleeve so the sleeve will stretch and just fall off. Blunt side, face side of hammer doesn't matter.
Now, to get the outer shell out of the LCA there are a few ways. Cut it out, chisel it out, or press it out. To press it out (imho is the easiest), just weld a washer (1/2" hole size is what I used) to the shell flange. Get good penetration on the shell or it will rip off. Flip the LCA over and press it out with a solid bar, long socket, etc. You could also hammer it out if needed but to get this assembly back together a press is the best tool.
