jeff edwards
anyone have knowledge on swapping a 383 to replace poly motor? torqueflight compatability etc thanx jeff edwards
thanx darter6 learning curve is steepTranny won't work as the poly is the small bell same as the LA block.K member will work with the right mounts.Look up www.engine-swaps.com for more info.
