WTB Wheel Hub to fit 11 x 3 front drum for a 1969 Roadrunner
Denis Boucher
3:01 PM
Barnstead, NH
My drivers side wheel hub on my 69 Roadrunner is defective. The car has 11 x 3 inch brake drums. Anyone out there have a hub available?
Thanks
I believe i have one. Shipping might be high from Indiana.
Hello and thanks for your response. Do you have a hub or hub and drum combined? If you do have a hub only, were the lugs pressed out right from the get go or, or was the swage removed first prior to pressing out the lugs? If the lugs were pressed out without taking the swage into consideration, the splines that grab the lugs get damaged causing the lugs to be so loose that they spin when loosening or tightening the lug nuts. I prefer to buy a hub/drum combo that has never been separated so that I can separate the hub from the drum properly.
Thanks
Denis
Will check tomorrow and take pictures. I can't remember which side I have.
OK great. FYI, if you have a drum/hub combo, the distance from the outer surface of the drum to top of hub is 1 9/16. The distance from the flange of the hub (inside drum) to the top of the hub (where outer bearing is) is 1 7/8. If no drum is mounted to hub, the distance from outer flange of hub (that mates up to drum) to top of hub (outer bearing) is 1 13/16.
Here are some pictures of what I have. This is the way I got it, did not take it apart. 11" x 3" hub. It is marked 68, I believe same for 69. Start a conversation if interested. $60.00 for everything plus shipping.
Hi Randy
Thanks for the photos. All I would need is the hub. It looks like the splines in the lug holes are gone which means the lugs will most likely spin. Your opinion? Would you use the hub?
Denis
View attachment 373776 View attachment 373778 View attachment 373779 View attachment 373780
Hi Randy
Denis
There is some spline left , not totaly gone. I had some new studs in a can, but not sure of the size needed. Some were loose, and some were tight. I would probably use it.
Thanks
Hey Denis, I've got a hub for you if you still need it. $10 plus shipping (approx. 6 lbs). Will need lugs, bearings, and races but good otherwise. Let me know@ [email protected]
