rt-man
I want to put a stock appearing, SB street engine in my '73 Satellite Sebring Plus (318 now). Max HP is not the goal, but torque below 2500RPM is. It will be a cruiser, never seeing strip time (below 4500 RPM). The issue is parts availability versus budget.
Rationalization: don't need aluminum heads due to no need for high RPM breathing.
360 vs 408: 408 has more volume to generate more torque. Can I get the same torque out of a stock stroked 360 with correct cam choice? Is the 408 stroker kit wasted on an iron headed motor?
LA vs magnum: I want to keep it stock looking, period. No high rise intake (i.e. Edel Air Gap). If I go cast iron magnum heads, no one makes a low rise dual plane intake for use with magnum heads. MP P4529116 but discontinued. Then we're off to LA heads. J heads are pricey, do I need 'em? But then I can go with any early intake (i.e. LD340). 308 swirl heads? Will they accept an older low rise intake? 302 heads don't flow well without a lot of work, correct?
Iron manifolds: 340 HP exh manifolds...pricey
Conflicts, conflicts, conflicts.
I'm an enthusiast, not a mechanic. Quench, open chamber, valve size, etc. are part of the equation but not my area. Thanks.
