Ski 61701
- 1:42 AM
- Nov 21, 2016
- Bloomington Illinois
I went and ordered the stubby fan clutch and a replacement fan blade to put in my 64. I have a rb in it and the oem 3 core radiator. As my luck goes, with the radiator mounted I could not get the clutch /fan assy in. Removed the rad installed clutch assy on water pump, weasled rad back in and sure enough I have about 1/8 in clearance from the leading edge of fan clutch to rad core. Any suggestions, I really dont want to go back to a fixed blade fan if I can avoid it. But obviously cant run it that close to rad due to motor movement.
