my '63 Fury has large ridged aluminum panels on the rear. I had posted earlier about ideas on replacing some broken retainer studs now working on this. The other panel I'm trying to brighten up before I paint the channels these panels are likely anodized. Reading up on restoring there are a ton of ideas likely good and not so much. Some say it's required to remove the anodized surface to do anything, a few others have talked about ways to improve the finish without removing the anodizing that would be preferred since once you remove it you have to recoat or plan to wax it every other week. One guy talked about brake fluid (doesn't sound wise) and another using WD-40. I reckon I'll try this as sounds safe enough or a penetrating oil. Anyone having done this sort of work would appreciate any tips or advice. Thanks.
