FOR SALE big block parts
lewtot184
1:52 PM
indianapolis
Feedback: 2 / 0 / 0
new set of kb184-.020 pistons with new seal power e-424k-20 rings, $400.
lightly used (couple of hours run time on mounts) big block shumacher poly-loc mounts and brackets with hardware. these came off my '69 r/t and should fit '66-'70 b-body and e-bodies, $150.
new engle k65 solid cam and tappets ([email protected] lift), $150.
new comp cams 282S solid cam and tappets, $150.
new hughes HE-3038 hydraulic cam and tappets, $150.
new crane #64673-16 bal/cup push rods for adjustable rockers and hydraulic flat tappet cam, $100.
new sealed power 4924 MA 20 main bearing set and clevite 527p-20 rod bearing set for RB engine (some dial bore gauge marks on a couple of bearings), $125.
parts can be delivered to the Indy show. pm me here.
How much for these "big block shumacher poly-loc mounts and brackets with hardware"
I guess you have PM's turned off?
I'll take the engine mounts if still available.
I don't know why but I can't contact you, give me a PM with your mail if you can, time to go to bed now in Sweden if you accept Paypal you can consider mounts as sold.
