Brianp
Do B body and A body cars use the same manual steering box ? I am removing a power unit to put on a manual but the pitman arms are a lot different. The power one is longer and has a bigger out put shaft.
your in pa, mopar country, Ill bet you can find a box easy that is made for the car.No the spline and out put shaft to the pitman arm is smaller
