Let's see some engine shots !
Freshening up my first car..never got rid of it, thankfully. 1969 383HP Sport Satellite. First refresh was 1979-80...refresh 2 in process.
View attachment 393227 View attachment 393228 View attachment 393229
Here are a couple more shots after shop installed motor. Will be swapping out upper radiator flex hose to a molded hose as soon as I find one that fits...
1963 426 wedge std bore marine block with stage 3 heads waiting for assembly for my 63 Plymouth..
Here's mine, still some finishing to be done but it goes ok!
361 HP in my 62 Fury............... flash made the color distorted it is actually the correct turquoise.
1953 331 HEMI.
Max Slant in my 64 Savoy.
can I ask what radiator you're using?
It's the 26" Griffin for a 68/69 Charger with a big block and a stick. GRI 5-00004. I trimmed the core support out from the 22" hole so I get full air flow and then I used the new Mopar fan shroud. Fits like a glove just not enough room for the battery in the stock location.
