I am in the process of re-wiring some of the circuits in my 65 Belvedere in which there is s '70 440. I am "running blind" a bit in that it is somewhat of a barn find as I purchased it from a senior gentleman who knew little about it...except that it was loud and I think he got more than he bargained for and decided to cut his losses. ( The wiring under the dash is somewhat of a cobbled " rats nest" . )
In any case, what would you consider to be the best source for switched 12 volts. I will eventually be putting in a 7-circuit Painless wiring module under the dash for gauges, tach, MSD ignition, etc. and would like to keep this as clean as possible while not having to do it twice.
( And as a very old senior myself - well it does happen! )
In advance than you for your help .
Ted
Ted
