tileman61
got in gtx tonight dome light wants to stay on with doors shut map light on also when u take bulb out of dome light map shuts off and map light works fine any help thank u
Map light goes on off when u open an close doors with ignition on u put emergency flashers on map en dome light blinkLooks to me, like you have a wire going to ground somewhere in you dome light circuit. Not under the dash but somewhere between one of the door switches and the dome light. Maybe one of your door switches has failed since that is what the door switches do. Provide a ground to the light when you open the door.
