68 Charger Wiper Blade Refills
The Rebel
2:39 AM
SW CT
Hey Guys. Went thru the FSM. OM & the Parts Catalog but can't seem to find what the orig blade size is. Currently I have 15" for both sides. Went to a few part stores today & seems no one sells the replacement blades anymore. Anyone know where to get refills?
I found that the cheap wiper arms from AutoZone have the type of blade which can be removed and inserted into original arms. With my 71, the clearance under the cowl requires the blade change method only. Replacing the whole arm causes it to get stuck against the bottom of the hood.
Thanks guys. Not sure if this helps but here's a picture of the one I have.
