FOR SALE Parting 1969 Plymouth Satellite
"A Pillars are different between 2 and 4 door cars."
I hear this all the time, but I disagree. I personally took A Pillars from a 4 door '69 Coronet and put them in a '69 road runner and they fir perfectly.
A pillars are taller on a 4 door car- they are different.
If you got a 4 door A pillar cover to fit a 2 door car I say good job. Because they are different. But I supposed it could be done. Any chance do you have pics if the install? I have a pair of 4 door A pillar covers that are black and I need a pass. side cover for my 68 Charger.
Here are some pics of the differences. Top A pillar cover is from the 4 door. In the 1st pic I used a straight edge to compare the profiles of the two.These are the driver's side pillar covers.
vrhdbmh bpi.jpg vrhdbmh bpix.jpg 20170523_150218.jpg vrhdbmh bpixx.jpg 20170523_150245.jpg
View attachment 426999 View attachment 427001 View attachment 427002 View attachment 427004 View attachment 427005
Spot on
sorry, this was the car. all I know is I pulled the A pillars from a '69 four door Coronet at the junkyard, and went home and put them in my road runner.
Do you still have the wiring and lens for the right fender blinker indicator? I guess left or right would work. My right side lens is cracked and the wire looks like it was yanked out.
Pretty sure that I have it. Think I have some new drums as well
thanks for the reply back. what i need is
strut lever with the spring
parking break lever
the top triangular piece between the shoes and springs
the 2 push rods from the wheel cylinder that pushes on the shoes
all left side
parking break lever
all left side
Are those the same parts that the 10" application uses? I would think that the top triangular washers would be.
