- 6:44 AM
- Feb 20, 2012
- Maskachusetts
Has anyone got a diagram of what hoses go to what diaphragms?
No, you have it upside down. The bottom row has 4 holes and the top row only has 3 in Figure 1.Last question;
Is this the correct orientation as viewed on the drawing with #1 being the bottom left on the row of three & #7 being on the top left?
Floor heat is controlled by two small doors on the bottom of the unit that are manually opened and closed. Small wheels stamped floor heat.All the vacuum lines are hooked up properly and things seem to be working with the exception of the floor heat function; it still blows out the vents. Any thoughts "Oh Wise One"?
