- 7:44 PM
- Sep 25, 2014
- Dahlonega, North Georgia
I have a 63 Polara that had a front disc brake conversion installed, but nobody knows what kit was put on it. Without taking thigs apart I can see that the caliper bracket on passenger side has part #2627BL cast onto it. Is that enough for somebody to know what parts were used in the swap so that I can look up correct caliper and pads or do I have to tear it down further.
Attached is a pic
Also what might cause fluid level in front of master cylinder to go all the way to the top when it was only filled to about 1/4 below top?
Thanks!
Attached is a pic
Thanks!
