1963 fiberglass dash search
jabird
8:13 AM
illinois
Does anyone make a complete fiberglass dash for the 63 dodge 330/polara? I have several good steel ones but id prefer not to cut one up. Any help or direction is appreciated
I had heard they made some but it wasn't listed on their site, I may have scrolled past it though. I'll try calling them Monday, thanks for the suggestion
This is Larry @ Sled City Fiberglass! What I used in my 62 Plymouth wagon is one of my Sled City 64-65 fiberglass dash boards. Looks good and looks stock to the unknowing eye. You have to trim the dash up by the windshield and do some trimming on the steering column support. That support is an overkill from the factory and a good place to loose some weight. I used a 64 Plymouth cluster with the s/s delete plates on both ends. You could also fashion your own insert and gauges Price on the dash is only $280, and is a popular item. Go to my website and call me. I can text you pictures. Texting is a popular way of me doing business. www.sledcityfiberglass.com Can the dash hold a radio? Properly braced, I think it could hold just about anything, Garmin, C-B, radio, 8 track, mini tv, or what ever. -----can't forget the drink holder.
The biggest weight in the 63 is the cluster. An aluminum plate with the gauges and some bracket trimming they can get pretty light. Use only the ash tray and glove box door outer skins.
Agreed,Jennie Craig made those out of aluminum:usflag:
I will also speak to lee and determine wheather I take a hole saw to the trans X-member or aluminum.Will also add a midplate and engine limiters that don't exsist yet:realcrazy:
Bumping this up for info. Glasstek makes a glass dash and rear bumper for a 63 Dodge. They are in their catalog as 63-64 Dodge but they are both 63. I picked up one of each last evening.
I make hood fenders lower front valance trunk front and rear bumper radio delete plates headlight rings and we use a 64-65 dash. And 3 sizes of bolt on max wedge scoops. Thanks for asking about my products.
