prime the motor by pulling the distributor and using a hex shaft
What wyrmrider said.
But, a little help, especially if the timing is already set, do this...
By hand, turn the engine over, until the timing marks line up, on compression stroke #1.
That's simply because you have to pull the distributor, and distributor drive shaft out. No big deal if you get things off, just means you'll need to re-time it.
Before you pull the distributor, note the direction the rotor is pointing. Pull the distributor.
Then, take note on the slot position, top of the drive gear. Sounds like alot, but really isn't...just helps get the parts back in right.
Drive gear needs to come out, slight rotation, as it does. Pre-oil shaft goes in that bushing, hex end into the oil pump drive hex. Do the pre-oil, forcing oil into the empty ports in the engine.
Then, re-install the drive shaft, and distributor, same positions they were in. If right, engine will at least start, only needing the timing checked, and set as needed.
Bottom line...the engine has oil where needed, before you fire it off. No difference than a fresh re-build, but already broke in!
