Clay Dots
Been tryin to get my new tank to fit in right and it seems like the old straps just fit to loose and soppy, really hard to tighten up the screws at the front of tank, sockets not deep enough so lots of frustraition trying to get it tight enough with a open end wrench, had this thing on and off about four times now, and resorted to puttin some high density foam rubber on straps to make them fit tighter, anybody go through this? did u have to buy new straps to use with new tank or did you use your old ones.? also the shop manual shows a l shaped bracket on the filller tube, but mine doesnt have one? and my electrical connecting wire to the sending unit is missing in action as well? any ideas or suggestions???Thanks much!
