Found them atI'm looking for the same item.
Your wish list contains 1 item and is shown below.Found them at
Parts Mix I am on the road right now but can send you the link in a little while
The reproduction glass channel runs are very fragile and easily torn. You might also want to reuse the original "H" pins as the reproductions tend to be a bit oversize and wants to bind up. If your originals are cracked and no longer hold tightly, just hit the edge of the nylon pins with a file or sand paper and take a bit of the material away.[/QUOTEGood to know, thanks 69bfan
