I have a replacement trunk lock for my 67 Coronet. I need the clip and ring that holds the lock mechanism in place, anyone have a spare or know where I can get one?
Thanks
I have one of each size......send me the exact inside dimension of the opening and your address and I will send you one. NO CHARGE.I have a replacement trunk lock for my 67 Coronet. I need the clip and ring that holds the lock mechanism in place, anyone have a spare or know where I can get one?
Thanks
The kit above is sort of 'universal'. Those rods connect the lock cylinder to the trunk latch.
I would think so. Cutting should not be an issue. If you need on with the dog leg you might have to twist or bend it to fit.
