ord27
I've pretty much mapped out how this harness connects to everything.
I've decided to not connect/purchase/repair the headlight delay and the key illumination features
I am lost on two things:
The double white wire in the wiper switch section. It has a round female plug in connection. Is this just an accessory ground?
I used a white jumper wire for the jump between switch and pump switch
Also, sort of in that same harness area, is a 2 prong connector with one side having a pink wire and the other having a black and and a pink w black stripe.
any ideas as to what this goes to?
I'm guessing either a tach, or center console
