Triple Black 73
So, I'm having a devil of a time trying find the happy timing for my engine. At 15 degrees of timing it idles good, but spitting and popping at WOT. And at 18 degrees, it surges at idle, a rocket ship at WOT but pings on the highway when going from 60 to 80 at part throttle. At 12 degrees it idle great, but it's bogs like crazy between 1k and 1.5k and chokes itself WOT, but handles the highway just fine. I can't find a happy medium! Oh, and it always runs hot.
Here's the specs of my boondoggle of an engine build:
383 bored .60 over
About 9:1 compression ratio
346 heads, no porting
Compcam XE256H
Holly Dominator Single plane intake
800 CFM Themoquad - https://www.summitracing.com/parts/sum-210234
Stock ignition
Not sure on the spark plugs. It's what RockAuto recommend for 4bbl.
I'm thinking I need 18 degrees, a larger mid range needle, and set the idle richer. But I don't know. That's why I'm asking.
383 bored .60 over
Compcam XE256H
Stock ignition
