Preval sprayers work great for small jobs and touch up.
Rebel - you should go to your local paint supply and see if they can use the camera to match your paint color. Odds of matching color based on a code are slim to none. Once they do that, they should be able to make spray cans.
The original pp1 had lead. You will need the not environmentally friendly mixture to duplicate the correct color. I went through this already. Use PPG.
