Finally about to get TrickFlow 240s. A question about spring options...
The components on the trick flows are good pieces. I wouldn't mess with them, other than to check them.
I updated my 440 .030 over 505 Stroker, with the "802" TF heads, did the whole top end from Trick Flow, with 440 source 1.5 ratio rockers used on there Stealth heads, and Crane 271-68532-16 lifters. Picked up over a 100 HP and 65#'s of torque. Was at MATSLV this past weekend, ran in the 11.2's, and 118 mph on 4.10 gears. Was a great pickup from 2017. Compression is at 10.9, on VP 101 fuel.
