1968 -69 and maybe 70. floor plugs
Cornpatch MO
6:30 PM
Southwest Iowa
I painted my floor and took out all the body plugs. I never kept track of them , but noticed most are plastic, but some are rubber. I got my new plugs and some are rubber too. . why were some rubber from the factory, and does anyone know where they go? Thanks for any help...........................MO
On my 65 Dodge had 4 rubber plugs. They were in the flat area above rear axle, put in from trunk or from interior behind cross brace.
Look through my thread....I detailed the placements
That will help a lot. Bit of a puzzle as to which ones are rubber and the areas of the close up pics, but I will figure it out.
Still wondering why some are rubber?............................MO
You are welcome to pm me your number and I would be happy to clarify this for you if you run into a snag....
Justin
Well, figuring out which holes take the rubber plugs , and which ones take the plastic was easy. The plugs are sized so that only the rubber ones will fit in the correct holes...................................MO
