KramerSwinger
So I have Edlebrock E Street heads (part #5090) for my 73 400 big block. I’m also running Holley Terminator EFI. I had ordered, with the efi, a Holley dual sync distributor (part #565-109).
Below, I’ve uploaded the distributor install attempt.
As you can see, there is a bit of interference with the cylinder heads. Holley has no other options for me to run and Edlebrock tells me I have maybe a 1/4” of wall thickness to play with there.
Would you recommend clearancing the Head, or just live with the stock ignition?
