Thoughts on Wheels/Tires for '79 Cordoba
Play with photo shop, print possible winners on the wall, let it sink in for awhile.
If you're still interested in "unconventional" wheel/tire sizes...
Here's a (not great) pic showing 265/60 16s on 16x8s w 4.75" bs on the back. The front has 235/60s on 15x7s, 4.5" bs... but I should have gone 245mm. In this picture the rear ride height is 1" to 1.5" lower than normal... I had just replaced an air line.
Once you get your ideal tire width and diameter decided, try this gizmo https://tiresize.com/calculator/ to translate it into a usable real-world tire size.
Thank you. I've decided to stick with the factory setup and because I do have a set of NOS hubcaps with the centers & decals as well.
