Still have this dam pop,or creaking going on,have torque the bolts to 85 ,so my question is do i have to support the lower controls arm to remove the uca bolts.and have a look at them.71 satellite
It easier if you support the lower control arm, otherwise its pulled down onto the rebound bumper. Use a floor jack and lift it enough so the upper is not loaded.
