m79ded
I have a 79 Magnum with a 451 TFS 240 10.75 comp and makes just a touch over 600HP. I am very happy but the temps are more than I was used to and more than I'm comfortable with. It has a flowcooler water pump and a 180 stat in After some spirited driving it keeps running around 200 +. It has a 3 core 28" rad that is about 2" wide as compared to the early cars that had rads that are about 3" thick. I wanted to drain rad and add distilled water and a additive. Which do you recommend from the 2 I asked about?
