Mstone68440RR
Still trying to get my 68' RR on the road and figured out. I received my 3rd MSD 6A (2nd replacement unit) last week. Upon the advice of a mechanic friend I disconnected the the alternator output wire on in addition to replacing a suspected bad voltage regulator
Fired the car and it started right up, ran it a few minutes and shut it off. Started it again and got a voltage reading of 19-20 volts on the alternator post? I know that has to be high, and assume it would cause the previous MSD units to fail from over voltage had the regulator failed or not been able to correct that high of a voltage. Also, just after the reading the car died again. And again no spark at the MSD. This was with a new regulator and the alternator wire disconnected.
I then removed the alternator and took it to Auto Zone where it passed lamp/ diode, regulator and rectifier tests on their machine.
The alternator was on the car 4 years ago when I bought it, I recall the previous owner saying it was new and a high output 70 amp model.
Shouldn't the voltage output from the alternator be in the 14-15 volt range?
I suspect this is part of my problem but still not confident that this is the only issue.
