Jetblast
This is a list of parts I have to sell that I would bring to the show or I can ship.
I have a BB Bellhousing available. It is 69 vintage, 11" clutch and casting ends with 626. Has the ball stud only. $375.
The 906 heads I have have been done with a three angle valve job and comes with valves and springs They are disassembled because they have not been lapped. $400.
High Performance Exhaust is 68/69 and has 280669 and 2843992 casting numbers. $425.
HP Exhaust 1970/71 casting 2899879/2951865 $425.
Clutch style 8.75 rear end. The ring gear has some teeth that are chipped on the outside edge so it has comes with a new ring and pinion set in 3.23. $425.
Set of Eagle 6.7 connecting rods, brand new. $325
Set of LY rods has new ARP bolts installed. $200.
1966/67 B Body clutch petal set, perfect restore $475.
65 Belvedere Tail light assemblies driver quality $75.00
11" bellhousing, great condition, no cracks no stripped threads $325.
Petal sets, I have several let me know what you need and I will get back to you with condition and price. $250-325.
Steel crank 20/10 over $275.
Several sets of heads 906 and 452 Let me know what you need.
69 HP manifold set, blasted and primed. $400.
65 Coronet tail lights $100.
65 Coronet right fender, rust in usual place behind wheel well. Otherwise very good condition $250.
65 Coronet Hood. Very good condition $
375.
65 Column shift column w/ wheel $100.
65 833 transmission $425.00
Drive shaft for above $100.
375.
