levicah
Can somebody educate me. TDC is when #1 piston is at the very top of it's compression stroke, is that correct? Shouldnt this place the notch on my crank pulley at zero on the degree marks on my block? or at least near it? So, the distributor rotor, should also be facing the #1 terminal on the cap?
When #1 piston is as high as it can go...pushing out air, as in "compression", the rotor is 1 inch short of pointing to #1 cap wire. Also, the tds notch on my pulley is nearly 1/3 away from the timing marks.
So what is happening here? Is it only the distributor position?
I thought that notch in my pulley was set in stone??? I dont understand. Do I follow the notch, or the up position of my #1 piston as TDC??
