451Mopar
On the 1969 Coronet R/T Convertible, I currently have the six pack style hood (steel hood with fiberglass scoop) on the car that I used when i had the RPM intake, Holley Carb, and tall air filter. I changed the Intake to Edelbrock XT EFI which can now fit under a flat hood.
The Hood that came (but car is not coded N96) with the car was the Dual Scoop Air Grabber setup. It looks nice, but I'm not sure it will fit with the under hood air grabber? I'm going to try it and see if it fits, but not sure. The car does not have side scoops if it matters?
I do have a correct bulge hood in primer that I could use. The inserts need to be restored, but it would be correct for the car and should fit with no issues.
Which Hood would you use? Sorry I don't have pictures of the car with the bulge hood.
