Auto Teach
Who is the best vendor to purchase these from?
That's very true 69bfan. The first set (no mention of brand or vendor) I bought were no where close to fitting a 65' Belvedere 1. I wish Wiskers would add aluminum pop rivets to their kit instead of (however, original) staples.
If you have a trick for using the staples, I'd sure give it a shot?
Love that interior!You can try to find and use the original holes for the staples or drill new ones. Very small rivits work too but are harder to hide.
www.forbbodiesonly.com/moparforum/threads/taking-up-new-residence.114133/page-26
Beautiful car!!You can try to find and use the original holes for the staples or drill new ones. Very small rivits work too but are harder to hide.
26
Khryslerkid, very nice write up on the installation of the felts. Very detailed and the results of your efforts shows the quality of your restoration, job well done!!!!
The reason that we do not include a pop rivet or screw with the felts is that the felts were never installed in that fashion. Depending upon the application, we provide what was used back in the day. By 1971, you did start to see that some of the felts were starting to be installed with several screws.
That is not to say that a pop rivet or a tiny screw would not work as well or even better. Most restorers have the abilities to adapt to the situation and use what they feel most comfortable with.
Some models require different parts....Help me out guys I might be mixed up..on my 68 the window fuzzy pieces attach to holes in the sheet metal with metal tangs that are on the backside of the fuzz strips, but you are referring to staples and rivets etc..is that just how they worked for some years or are you talking about a different part? Thanks
Ok good so same piece different year. Thanks for clearing that up for me (glad mine are the easy ones!)Some models require different parts....
