wagone to far
moparsquid
5:40 PM
spring valley ,ca.
hello got an offer on a 67 bel wagon that's very rusty but runs good my question is will body and floor metal work from a 2 or 4 door on the wagon and who has them,thanks
Look at Auto Metal Direct (AMD) and see what they make. There's also Sherman.
Two doors and 4 doors share nearly all under the skin sheet metal such as:
  • front inner fenders
  • Firewall
  • Cowl
  • front floor pans
  • inner and outer front door posts
  • rear footwells
  • rear floor pans
  • trunk floor
  • front and rear frame rails
However when you go to a SW....I believe the variance starts somewhere around either the rear footwells or the rear floor pan. I believe the SW had a longer wheelbase.
That being said, your best bet is to find a clean 4 door donor as you pick up benefits such as the windshield and doors (as long as it's the same model year). Otherwise....there are a lot of new panels you can get from AMD or Goodmark that will help repair your SW.
I also believe that the 66-70 SW's were pretty much identical underneath the outer skin....so they would be great donors if you could find one.
