do you have any pixsWent with vintage air on the 66 coronet it runs the lines under the passenger side fender and they feed into the engine compartment via that suspension adjustment hole in the inner fender panel. The condenser connections mimic the factory routing going over the top of the radiator core support. We slightly bent the aluminum lines and put them through a oval shaped hole we cut in the core support for a cleaner look on our installation.
I am thinking of going with that Vintage Air system , but a little skeptical about running the lines into the fender well and out through the alignment access hole. Where do the lines run into the fender well? Won't they be exposed to road debris? Pictures would sure help......................MOdo you have any pixs
ok,thanks for the pixsProtection is easy to make. I made this out of .062" aluminum from Lowes to protect my fuel injection pressure and return hoses. BTW, I have Vintage Air and it works very well, even in a drop top...View attachment 638002 View attachment 638006 View attachment 638007 View attachment 638008
can someone post pixs ?
