Flat tappet cams, both hydraulic and solid, have a taper ground into cam lobes amd lifters that push the cam back into the engine, both to locate cam properly, and to rotate lifters for longevity. What d3te4mines cam location therefore is the face of the cam gear that rubs on the front of the block.
Roller cams,both hydraulic and solid, due to having a wheel on the lifter, cannot use a taper, therefore they must use a cam button, and usually some reinforcement of timing cover. Almost all rollers use a three bolt cam to be able to use a button. (I try to never use "always")
I would use the oil slinger, as previously mentioned, it helps oil the chain(and timing chain face to block) and keeps the front seal from being overloaded with oil.
