miller
Or rant?
Mallory dual point w/mechanical advance #2557801H. Found info stating if the H is in the #, simply means the distributor has YH type advance...the new, and improved??
Just commenting, on something I found, don't like, might or might not help others. My understanding is, there's other distributors that use the same type mechanical advance.
Grabbing the rotor, cam shaft, found up/down play about 1/4". Why? And no, doesn't help much having that much end play. So, I tore into it yesterday, to find out why. (This is by no means my first Mallory dual point, though it's been many years ago.)
Maybe I'll post some pics. The 'weights' are fairly thin metal, held onto the advance plate with E clips, and a pair of nylon bushings, one top, one bottom. Looking at all the end play, those weights flop around pretty good, up and down. How's that for a precise piece!
Put the advance parts back together, but going back into it today, and see what needs to be done. Sure, needs free play there...but, not that much! Makes me wonder what it's doing, running down the road.
