- 5:46 AM
- Mar 28, 2014
- South Louisiana
Can you explain that in greater detail please?Center counterweights are a plus.
I actually corresponded with that guy.Superbird front end for when you need it ..
ORIGINAL SUPERBIRD NOSE CONE, HOOD AND 2 FENDERS FOR SALE
« on: November 13, 2017, 03:28:47 PM »
I have acquired an original Superbird nose, hood and 2 fenders from a body shop that has had them for 20+ years in storage. According to the body shop, they all came off the same car which is possible since they're all orange on the inside. They are in very good condition and would need very little work to make excellent. The nose has a few pin holes on the bottom center section and a little rust around the bottom openings but was never damaged/bent as far as I can tell. The hood and fenders are solid and also seems to have never been damaged, dented or bent. As you can see the hood and fenders are primed gray which is how I got them. The undersides are not primed though and it seems that they have not been patched either.
Needless to say, if you are doing a restoration to an original car this is a must have and it is a no brainer that it will add/retain the value to what is a very high dollar car. Not to mention that the fit will be like factory, unlike the reproduced parts that are out there. Also, there is a big difference in having factory original parts over a 70 Coronet hood and fenders that are cut and welded to make them into SB parts.
After doing some research on availability and previous sales of original parts, I am asking the following.
Nose Cone- $6000
Hood - $4000
Fenders- $2500 each.
I am open to selling them at a discount for a package deal to one person, but will sell by the piece too.
Due to the size and fragility of these parts, local pickup is preferred. However, I will assist in custom crating these parts for shipment, all at the buyer's expense, if they are not local. I am located in northern NJ, next to NYC.
I have detailed higher resolution pictures that I can email. Private message me on the forum with any questions or offers.
Thanks for the ad DC.COM !!!!
Logged
If you’re trying to gain some power and be cost conscious, why not just start with a top end swap to the TF240 setup, maybe a cam change “while you’re in there” and do it all yourself? You wouldn’t even have to pull the engine. Then, you could save for the stroker and build the short block later on as funds allow. After the top end swap, you might not even want/need the stroker.Another reason why I'm sitting on the fence now about stroker vs just a built 440...
My 71 440 motor has the steel crank with heavy rods. I'm guessing that the crank (it would be checked for cracks during the build, of course) would be fine, right?
I mean if I couldn't use my current forged steel crank, well I would go with a stroker setup for sure if I had to buy a new crank.
I would also believe that modern technology in connecting rods would mandate an upgrade there, right?
Did you check out the link to the cap and girdle set I'm sold on? It really is different and in my and my local engine builder's experience a better concept for strength from a materials and engineering design standpoint.
I actually discussed that on the forum and with IQ52. Jim mainly was my reference for what I thought was a good, efficient value for moving forward.If you’re trying to gain some power and be cost conscious, why not just start with a top end swap to the TF240 setup
Just my 2cents but Id not do anything irreversible to an authentic 440/6 car like Bios.Hell, I'd go for the Superbird conversion with a select variety of vendor parts. Life is short.
A Satty or 383 RR sure.
Bio sold the bench seat and it was really nice... I used a highly optioned, matching numbers B5, bucket seat, console, auto roadrunner for my clone. Numbers didn’t mean anything to me. I didn’t pay much for it so I used what I had. It might have been cheaper to restore it, lol.
When I bought mine in 1982,a clone would have cost me ten times what I paid for it.
I looked at a hemi bird in 1983. I couldn’t swing the 10G price lol. Seems like peanuts now!!When I bought mine in 1982,a clone would have cost me ten times what I paid for it.
Please share what you paid for that Bird in 1982.When I bought mine in 1982,a clone would have cost me ten times what I paid for it.
$4K, and almost had second thoughts,seemed like a lot back then,this is today.
I'll give you $8,000, so that you can double your money.$4K, and almost had second thoughts,seemed like a lot back then,this is today.
That Bird is a BEAUTY!!! Congratulations!!
