74Runneer
I called up both Crane and Comp today to see what their recommendations were for a cam for my 5.9 build. Stock bottom end, stock heads, air gap intake, headers, dual exhaust, FBO ignition, and an eddy 1406 carb 600 cfm (might upgrade this), 3.23 gears, street strip use. I want the long snout with a mechanical fuel pump eccentric on it. Stock heads flow about 190-200 cfm with 1.92 valves. This is a very mild build just to get me through the next 2-4 years and hopefully by that time my drivetrain will be able to handle more power (8 3/4), then comes the 408 stroker with decent heads...
Anyways, I gave them that information and comp recommended this cam:
COMP Cams 20-614-9
And Crane recommended this:
Custom grind
Lift: .531"/.552"
Duration @ .050: 220/226
LSA: 110
I would obviously get the springs that they recommend.
Anyone have any experience with these cams? The comp stick seems too tame to me, but I also dont want to have drivability issues.
COMP Cams 20-614-9
- Lift: .480"/.480"
- Duration @ .050: 210°/220°
- Lobe Separation Angle: 112°
Custom grind
Lift: .531"/.552"
LSA: 110
