Sonny
It’s all fun til the rabbit gets the gun.
As some of you know I’m swapping my 318/904 to a 440/727. The 727 trans came out of a truck/mobile home. How do I go about selecting the right speedometer gear for my 70 b body?
the height of your rear tire.As some of you know I’m swapping my 318/904 to a 440/727. The 727 trans came out of a truck/mobile home. How do I go about selecting the right speedometer gear for my 70 b body?
Yes, as these guys say..... you need to know your rear end gear ratio + the DIAMETER (height) of your rear tires. You might check brewer's performance for a calculator/cheat sheet. What you need to know is the number of teeth for your transmission speedometer gear. Brewer's sells new & used ones or you can search wherever you like. The gear is REALLY easy to install (though you'll spill a little transmission fluid if the transmission is already in the car).As some of you know I’m swapping my 318/904 to a 440/727. The 727 trans came out of a truck/mobile home. How do I go about selecting the right speedometer gear for my 70 b body?
I Shoulda thought about that prior to selling itIf your speedo was right before the swap, just put the 904 gear into the 727.
