FOR SALE Parting 1966 Charger
Grille $75 missing one mounting tab.
I'm interested in the steering column "collar" and the turn signal/ cancel cam guts if it is not a column shift.
oops it would be for my '68; is the steering collar from 1966 compatible with a 1968? I'm thinking the 1966 may be a much smaller diameter?
I am needing the roof rail weatherstrip molding drivers side---specifically I need the transition 90 degree piece between top of A pillar molding and the roof rail proper molding---this piece may actually be spot welded to the A pillar trim as it is on my right side pieces in which case I would just like the complete A pillar piece--thanks
