WTB A/C Compressor clutch.
493 Mike
5:25 AM
White Cloud, MI
Feedback: 6 / 0 / 0
Hi Guys,
I need a RV-2 clutch for my 1965 Coronet. I don't care if the bearing is bad/noisy, I need the pulley and hub. Thanks.
Mike
I have a used Double groove pulley, Will that work for you ?
I don't know. Can you send me some measurements: O.D., Face to front groove centerline, and groove to groove centerline?
Mike
Double groove clutch pulley assembly will not work on a 318 poly A-engine A/C system. Diameter and position of pulley grooves are vastly different.
